Well, here in Arcadia it's 2012 & they are still using them on the RR. I saw some in Bartow & Plant City about 3 months ago.![]()
Hi Zoe,
Yes, the stand has been around a long time and as Larry said still in use.
Alexander Scales Models makes one almost Identical to that one as well as NJ but I'm not sure if either are still in business? Both were functional too but a bit of a pain to get positioned properly.
Caboose Industries makes one that I use the 204S High Level Switch Stand. The 'S' stands for sprung as the throw bar has springs in it which holds tension on the points so they connect with the Stock rails fairly firmly.
It's fully functional too and rotates the targets for a visual during operation so you know which way the points are thrown. It also comes with various style of targets and connectors. I just bend my throw rod at a 90* angle and insert it in the hole in the throw bar on the machine.
I also added a small bit of white Teflon grease to the mechanism that works the throw bar.
I just ordered eight for myself from my supplier
Here's Cabooses site, the High Level 204S is just like the one shown on the main page.
http://www.cabooseind.com
Your welcome Zoe,
I've used the Caboose Industries High Level Switch Stands HSS the past with very good results.
The problem I had, was my heavy hand in attempting to force the little throw arm when the points were stuck for one one reason or another?
This always seemed to happen when track crew weren't around to correct the problem. I guess the little folk think they are just supposed to stand there and look busy.
In actuality my heavy hand trying to force a stuck or hard to move set of points, on my home made switches, with the sturdy but somewhat delicate shaft the throw is connected to caused the damage to the shaft and rendered the HSS disabled.
I still have one of the old Caboose HSS in use from years back so let me compare the control arm shaft diameter no to see if it's still the same? They do look the same and if used with care should last a long time!
It's a Racor CNR type switch stand. The only truly accurate model is made by Custom Finishing. It's a costly proposition but they function...
Also need some spikes and plates to detail them since I only glued and soldered the rails on.
Thanks again.
Where can I view pics of your layout especially your hand laid switches/turnouts?
Hi Zoe,
I think I have some in my photos on the site under 'Trussrod's pictures'.
In relation to a prior post of yours, which I just got the jist of from reading Carey's post above, you mentioned something about tie plates on some other turnout that I guess was built to specs- [I didn't read it.] Central Valley had a line of flexable ties for both Branch line and main line as well flexable switch ties
made in a single unit and all of these had prototypical and in scale tie plates molded on top of each tie that of course positioned the rail weather hand laying your own as I am or building the switches. They don't have any holes
predrilled for small spikes like Micro Engineering sells but the highly detailed ties and plates drill easily with a High Speed Steel drill bit. Whoever made the molds for Central is a master machinist as the detail is phenominal.
I used to have them available through my prior supplier but when the owner passed away that all went by the Wayside! Damn!
Keep in touch as I see if I can't go direct if Central Valley is still in business?
I have a box of CVR branch line ties put away because I couldn't decide on how to lay the rails on them. Someone suggested I only had to glue them on, but I like my rail a little more sturdier than that. As for the drilling, I wonder what size bit is required and would it break easy.
Walthers Goo, when used as a contact cement, or heated by a soldering iron after placing the rails on the ties, will hold the rail securely forever.
I used this method to hold rails down on some bridges on some of my earlier layouts. I applied the Goo to the rails, placed them on the bridges, (held in place with 3-point gauges), and heated the rails with a soldering iron. Some of these bridges lasted over 20 years with no problems.
Say Zoe,
In relation to what Carey mentioned above, no offense meant Carey, but I would strongly advise against 'it' if it's that permanent because should decide you want to or need to move the track slightly if it's glued down that solidly your going to be in a world of hurt.
Hth
http://www.osbornmodelkits.com/httpdocs/HO_scale_railroad.htm
This guy makes laser cut ones, some assembly required. Nice if you take your time and paint them. He said they can be made operational but you have to be careful.
$10 for a pack of 6
