Sound System Installations
Fergmiester
M.E.S.S. Maker
As I am now doing sound system installs I'm starting to find the quality of sound differs from tender to tender. I suspect this is due to several factors such as cavity size, speaker size, speaker orientation as well as system quality.
As there seems to be a new revolution or in some cases a revolt!
The question begs to be asked:
Tell us how you're installing your systems
What works what doesn't and what are you using and why
How do you like your speakers? pointing up or down, single or double, 1/2" or 1".
Fergie
As stated by someone on the "Other" forum
"I like mine Sunny Side Up":p
Fergmiester
M.E.S.S. Maker
This was my first attempt at installing a sound system
This was a 3/4" oval speaker installed in a LL 2-8-4. The sound system is a Soundtraxx LC 100 Heavy Steam. Sound level was weak and disapointing
After asking the question to several forum members it was suggested I should try using the Tender shell as the cavity. So I sealed it up tight and added a heavt styrene baffle.
What an improvement! not only are there holes in the coal but there was also a space at the rear of the coal bin. For an LC the sound is not bad at all.
Fergie
Hawkeye251
There's something to be said for modeling the steam era.... plenty of room for electronics gear in those tenders!
Your installation looks good.
RexHea
RAIL BENDER
Very neat installation, Fergie. Don't be afraid to add more holes in the coal load. Mine have about 3 times that many. 'Mo better!';)
Fergmiester
M.E.S.S. Maker
It gets better! This is another installation I did earlier today. Very tricky as I wanted to put in a very large speaker into an unusual space, a Vanderbilt tender. This is a CNR K5a Hudson with a Tsunami Medium Steam sound decoder and the sound is the best to date!
Fergie
