Ok, I am ready to build my layout I designed, found here, and I need some help to make sure I don't make a dumb mistake
The keys to my layout are being as light and portable as I will be moving a bunch over the next few years. I have figured out how I am going to make the legs/support setup but I have 2 questions.
My first question is should I put a base of plywood down first, and then a piece of 1" foam or do you think just using a piece of 2" foam will be enough? The rest of my benchwork will be 1 by 4s and I am just wondering if I will need the plywood to maintain shape and rigidity. I also need to know what the minimus thickness I should use, remember I don't want this thing to weight a ton but I need it to be durable
My second question is what is the hardware I should use for the bottom of my legs so I can adjust to maintain a level surface. Are you guys using tee nuts?
