Good afternoon fellow Ballast Tampers and Spike Drivers,
Hi Flo, where's Francine, oh she took the day off, so you have your hands full then. Just coffee for me, black is fine.
What does WW say: Clear at 82.9 °F - Feels Like 82 °F;
Winds are from the SW at 2.7;
Humidity is at 37%;
Barometer is at 29.56 in/Hg
Good morning ....
Sherrel ... Thanks for your compliment.
David ... The fence I am talking about looks like a wood panel fence in the photos, but actually it is metal and is dark rust color. Jim Hediger called it a wood fence in his column, and his creative wring described how he thought I may have made it. LOL It does not bother me though. Glad to have the photo published.
We have a busy day planned.... Hope to see all of you tonight.
Hi Garry: I read what you said about the fence being Corrugated but until I pulled the image of the Junk yard office showing Dawg closer and enhanced it a bit and enlarged it, could I see the Corrugated sheets that made up the outside face of the fence. These did come in sheets and those were really heavy sheets too. I have an old Barn across the road and up about a 150' from my entrance that is covered with the old Corrugated sheets, roof and sides. I'd bet each sheet weighs between 15 to 20 Lbs. I covered one side of my tool shed roof wit the newer lighter weight Corrugated sheets which worked out very well and made a quick way to repair a leaky roof.
Thanks! Bout a third thru building it, getting exited for track!
Not a carpenter or builder or architect so I'm not ashamed to say I have no idea what a 45 degree corner gusset is. I DO have an actual carpenter building the thing for/with me so I was having no worries so far. The thing is so level we are 'sinking' and it is 1/2 inch lower now than where we started, the floor is SO wavy-gravy, after the turn towards the back corner the shelf will 'rise' again as the floor drops toward the drain. He is doing most all the cutting. ( It's MY 'vision' but It's HIS 'final' design!) I defer to experience as much as possible in any and all situations! I'm qualified for brackets and assembly but that's it for me on bench work! I'da had it all on saw horses and 3/4 ply with no guidance! THIS takes longer but will last longer!
Say Paratrooper: It is an triangle that fits in the corner of the L where the two tables butt together to form a 45* angle across the 90* area to aid in forming a smooth radius for your track to bend across much easier. They can be made to fill the corner as much as you want/need.
Did my description help you to under stand better?
Good evening everybody ...
David (in CA) .... The corrugated fence is cast metal ... I paint track before installing it using flat brown and flat black paint such as a Rust-Oleum primer paint in rattle cans. I spray black, and before it dries spray brown.
Curt ... Thanks for commenting ... Your scene looks great with the GP7's ..
Terry ... Regarding long tunnels, I allow room to retrieve derailed trains from underneath the scenery. Usually that requires crawling under the layout.
Garry: Thanks for the info I may try that here and there?
Awesome photo, Curt. Your bridge really turned out to be a great focal point. Like the Geeps as well .. I'm just not a fan of the BIG modern stuff, although they certainly do shake the ground especially grinding up a hill.
Garry, your junkyard scene rates right at the top of my list. As David said .. Your attention to detail is like a fine artist.
As it appears that I miss all the early risers back there .. I am going to start posting late at night. Hope all of you are safe and dry and away from all the wind and flooding.
Come on Terry .. I'm waiting on you!
Now, if you have those peepers open .. Feast on this ...
Sherrel & Phil: This place does move a lot faster than it did, for sure!
Nice picture of the F units.
Good morning ! Darn, behind by 12 pages. Already on third cup of joe. Be back later.
Phil
Good morning guys rain here in my town looks like it will do this all day, Ya'll stay safe and dry.
model-a chris,
Say Chris: You seem new to me so welcome to the forums.
M-1 or Marlin lever action. If I could see it I hit it. Not good with handgun.
Phill: I'm not so bad myself with a rifle or pistol.
Always to be respectful David, that's what taught me...
Yip, too darn young that is...!
Say Milwaukee: Thank Your Sir, it's appreciated, but just David is fine with me, I'm sure you have done many things to earn respect for too as your showing to me!
