Necrosaro420
Is flex track a good choice for a layout? Also the little pieces that connect the tracks together (name?) what is the best type/brand of those to use? I plan on using the nickle silver track
Ahhh yeah I was checking out that thread after you pointed it out thanks. My question about that though is do you solder the inside/outside of the rail joints, or from the bottom? I assume you just put enough so that the wheels dont make a clacking noise etc
Jeffey, even with the gap, if you soldered both rails to joiner it is still rigid connection. how is that helps with any expansion contraction?... The open gap between the rail blocks allows for any expansion and/or contraction.
Well, actualy the setup i have is little differnent than most others. I use flex track straight to the plywood, no cork. So what I do is take off a couple ties at the end, put on the railjoiners, and get it in their square. Then I drill a hole and screw down the first end. the just bend it around, cut it and do the same.
So you should use joiners and then solder the joiners to the track, or no? Getting confused by some of the responces =) Thanks!
