yeah, MRC decoders are trash![]()
The MRC decoders are made to be compatible with MRC's own systems. If you haven't noticed it already, MRC decoders do not read back CVs except on MRC systems.
The part of the manual I was reading only said that you can change the address while on the main. It did not say that you can change anything else. If that is true for the MRC system, then I suspect that it must be true with other systems as well.
JMRI was devleoped with the user in mind and I am sure they added something to allow more options while programming with it.
Help is help regardless of the quality. YOU are asking for help. We are not obligated to help you. We are helping you because we (actually, this is my opinion so if you do not like opinions, close this window now) like to help fellow modelers. Being rude to people who may be joking, or attemtping to give you help is not the best way to ask. (why should we help you if your response is going to be rude?)
Did you try contacting MRC directly? They know their stuff inside and out and can probably give you better "quality" of help than we can.
There you go. The problem is with the MRC decoder and they blamed NCE. If JMRI hooked up to the NCE can program it, then it is likely that it is not NCE's fault.
you have to keep in mind that all companies do not make or adjust there stuff to be versatile with another companies product. nce does not have to make itself compatible to mrc's stuff.
Exactly, Which model # MRC decoder are you having issues with? I'll bet dimes to donuts, that if you check the model number against the NMRA's list of decoders that did recieve a conformance warrant that yours is not one of them. MRC kinda did thier own thing for a while, but is starting to build decoders that might achieve the NMRA's blessing.
Maybe someday everyone will. (Do ya hear that Mike Wolfe??)
Try programming cv 126 to "1". Do it on the main. That should reset your decoder.
It's actually CV125 to reset defaults, and it only resets 2 CV's, the short address and I forget which other one, it doesn't reset all of them, according to MRC support.
Must be a different version then. The owners manual that came with my Athearn MP-15 with MRC decoder says 126 is the factory reset. I have also programmed it with both Procab and Powercab, and found that the Powercab has enough oomph to program any sound decoder without a booster. None of your MRC decoders will program?
If there's something to be learned from this thread is that mixing different manufacturers' equipment is not a good idea....It's a bit like playing Russian Roulette....
I recently purchased a B'mann 2-8-4 with DCC onboard (B'mann decoder, made by Lenz...) and couldn't get it to run worth a hoot. I'm using a D'trax Zephyr. I swapped the decoder out for a DH163, and now it runs beatifully....
Some systems are better than others, but all will do the job IF you stick with that system's accessories....
I'll let someone else address the issue of forum etiquette....
