jmupton2000
John M Upton
I have always had a fondness for one offs, oddballs, the unusual so when a undecorated Proto 2000 SD45 was offered to me at a nice price (especially since here in the UK, they are as rare as hens teeth) I snapped it up and sought a suitable candidate for it to be converted into.
Step forward Southern Pacific SD44R 7399...
The first job was to dismantle the undecorated loco into its constituent parts:
In addition to the supplied parts of the Proto 2000 model, there are also some extra bits of which more in a moment.
Two areas need fairly major alteration, in this case both ends.
The low short hood will need a ratchet handbrake fitted and the usual SP nose light arrangement:
The end of the long hood needs the handbrake wheel recess removed, a replacement full length hood door substituted, number boards removed and again, a full SP light show fitted:
The short hood was reasonably straight forward. a notch cut in the top front of the nose for the Details West headlight part and then a section cut away from the side to allow the fitment of a ratchet hand brake recess culled from a spare Cannon Co nose kit:
The long hood has had the SP light show part fitted and the handbrake wheel recesses filled in with a section of Plasticard and along with the rear number boards (SP SD45's and their rebuilt variants never had any) model filler applied, allowed to set overnight then sanded flat, the holes left by the surgery to the low short hood also getting filler treatment at the same time:
At this point a start has been made on fitting some of the separate detail parts, in this case the roof fans have been put in:
A Cannon Co full height long hood door was used to reinstate the missing one at the far end where the handbrake wheel recess was, this has been carefully filed down on the rear to make it as thin as I dare so that it does not sit too proudly:
That's as far as I have got for now, still LOTS more to do before I even contemplate primer and paint!!
Meanwhile, anyone got an idea what this part is?
I am stumped!!!
I am stumped!!!
