I have been installing the signal wiring that I have threatened to do for a year and a half
. I now have the power districts wired and working, and will start breaking them down into detection sections probably after Christmas.
I was wisely talked into installing a PM42 for the districts, but one thing that I ran across that everyone failed to mention is they do not like the in-rush of current that QSI decoders have. The PM42 will operate just fine with only a few sound decoders in a district, but if you have a section with several then the 42 detects a short from the initial charging of the capacitors and can’t reset itself. Of course, if the capacitors are charged from another district there is no problem...until you short out the rails again.
Setting the OPSW’s in the PM42 helps, but that’s like putting in a larger fuse when you blow the correctly sized one (YIKES!). A way around this is to install auto taillight bulbs (#1156) across the command station inputs of the 42 to the individual outputs, i.e. Rail A to Rail A District #1 and (2,3,4), and Rail B to Rail B District #1 and (2,3,4), total 8 bulbs. Because of the"Positive Temperature Coefficient", they act as a shunt to this high surge current and allows the capacitors to charge without tripping the 42. After the charge, the PM42 breakers act correctly and the power districts are protected.
I realize that some of you all ready know about this and I do not claim to have originated the idea, but hopefully this will help others that are not aware of this potential problem.
