lmackattack
old school
Need an idea on what will work here.
I have a switch track that cant be sceen from a staging yard. the track leaves the staging yard, curves around and goes under a bridge with 3 tracks above, it exits into a large yard you can see but the switch track that lets you into the yard is out of view. The switch is commonly used by both operators and members who just set up a train and are entering the layout. I want to put a signal up that will note the switch position. (red /Green)
my issues
no room under this aera for a switch machine as there are storage tracks below it/ Its currently a manual ground throw. What options do I have here to get the signal lights to work with a non powered ground throw??
Thanks
Trent
my issues
Thanks
Trent
