layout-ioe
Hello,
Fabrication/Assembly for our first batch of WiFi products is ready to go.
Loco-Node 0001 has been signed off as seen above; we’re restarting 0003 and will follow up with the rest as each is knocked out.
Loco-Node 0001S-V1 has an integrated Li-Po battery charger for wireless and power free track operation. It is hybrid so will recharge in areas of track power. The product also has 32 bit sound, 32 channels, and stereo, 1.7 watt, 8 ohm outputs. 1Gb or 4Gb of memory is available. This uses 802.11 WiFi for communication. No command station is required. No track based signals are used.
http://www.layout-ioe.com/collections/wifi-nodes/products/loco-node-sound
Loco-Node 0003B-V1 has the battery charger but lacks sound. All nodes feature full prototype LED lighting pads.
http://www.layout-ioe.com/collections/wifi-nodes/products/loco-node-basic
I have two nodes that do not have the battery charger and are designed for 12V operation on continuously powered track. They also use WiFi for control signals.
Loco-Node 0002S-V1 has sound. The sound nodes also have fan motor outputs.
http://www.layout-ioe.com/collections/wifi-nodes/products/loco-node-advanced-sound
Loco-Node 0004B-V1 does not have sound, it too is designed for 12V motor operation.
http://www.layout-ioe.com/collections/wifi-nodes/products/loco-node-basic-1
Next up after the Locomotive based nodes are complete are signal, track, and accessory products.
I am taking reservations by email to schedule and plan the initial production run.
Contact_Us@layout-ioe.com
Billing will not occur until the product is ready to ship.
For more information see the web-site, www.layout-ioe.com as we’ll start posting more content as things firm up on this project.
This product uses wireless, 802.11 for communication as a M2M mesh.
The nodes use ARM9 CPU’s running Linux 2.6.
Orders under Railflyer on this project will be filled with the new system. These orders do not however influence the production number needed to launch fabrication/assembly.
As of now, we’re just under 50% of the required numbers on Loco-Node 0001 to meet our budgetary requirements for production.
Take care,
Christopher Howard, Phoenix-Micron Inc.
www.layout-ioe.com
Take care,
www.layout-ioe.com
