After reading past posts here I decided at last to add pulpwood to my cars. I am glad I have only 3 of them at the moment as this is not a quick project.
We have cedar here and I wanted a southern pine look so that's what I am going with.
First, I made a mold if you will out of the type cardboard you see on 12 pack soda pop. I wanted to be able to remove my loads so I elected not to glue them to the car. The mold fits like a glove into the car, measured everything beforehand with a micrometer, added masking tape to the inside and applied a brush coat of coconut oil to allow easy release of the completed load. (Didn't want my superglue sticking to the cardboard afterward, and the backing on the tape along with the oil prevented this.)
Rather than cut the wood with shears I used my dremel with a cutoff wheel, setting it up with spacers and a deck turning it into a small table saw. I didn't want to have a "pinched" look on the ends of the wood, and the dremel worked nicely for that. Taped 2 cardboard ends to my mold to hold it slightly tilted back on my work deck, and went at it.
So far after 4 hours I have cut wood for 1/2 a carload and have ran out of glue (2 tubes). Each log of course has to be glued and I am using different sizes of logs as this is what I have seen on cars in the past. I am 2/3rds through with one side and the logs release from the mold with no problem and fit into the car nicely. A toothpick is nice for seating the wood with.
So, until I get to town and raid the store of a large amount of superglue I am on hold.
Looking ahead, I am going to weigh each side and ensure they are as close as possible for balance. Weight wise, my cars are going to be on the heavy side but I am hoping this will not be a problem. I am cutting green wood and as soon as it dries it will be quite a bit lighter.
I probably going to have to give the ends a very light dusting with orange chalk to give the appearance of freshly cut pine, then seal with dull coat but other than that all should be good.
All in all a fun project, the expense has been with superglue, tried white glue first on a sample, didn't cut it.
I thank you guys for your ideas, was getting tired of looking at empty pulpwood cars and the store-bought ones I have seen are not very impressive.
