Since there seems to be a number of questions by people who are interested in getting into DCC and the fact that a number of systems are available, I thought that may be a description of what you have and likes and dislikes may be appropriate here.
Currently i am running the NCE System. I have had it for about a year after going through a number of months of see and trying what other people have. I Love the system because of it's user friendly atmosphere where the large controller that comes with the initial system displays a number of well identified buttons to do programming, Consisting, Accesory control, as well as cab selection. the speed control consists of both a thumb wheel for increasing and decreasing speed as well as buttons to do the same. Surprisingly, it didn't take much time to master. i have found that many of the engine CV changes can be easily done on the fly so i only use the programming track to set up a new engine.
The smaller cab that is available with this system is really great for the casual user. Usually within minutes i can have someone running trains and doing most of the things a regular operator needs to be able to control with relatively few keys.
I am also using many of the accessory decoders to run my switches and have set up macro's to route engines thru a number of switches on there way to a different line with just a quick command.
I have found the manuals to be fairly straight foward, but you do need to read them carefully. There is a lot to learn.
I am sure i am leaving something out, but wanted to see if may be others would join in and talk about their systems as well. hopefully, along with some hands on at a LHS or show, this might help people make a decision on what they might buy.
