I'm planning on using Walther's background buildings along the wall. I notice the "thickness" of the buildings vary. Are the buildings designed such that one track can service them when more than one building is use along side another?
Marshall
Marshall
I've used Walthers background buildings(6 diff. buildings)on my layout in the past & all I did was make room for the building that was a little deeper at the end of the structures. In other words I moved all of the shallow buildings up to the deeper buildings front to make the siding work. Later I used the fronts of the buildings on scratchbuilt structures that I used all over the layout.
If you have a space problem along your wall you can always cut off the back of the deeper buildings to line them up on a straight siding.
