The poop on snot
Extracted from the suffering sinuses of free-range Mojave male frogs as fast as our wranglers can round ‘em up and herd ‘em in … just kidding!!
It is a sophisticated, specially secret formulated, room temperature curing, one-part “green” liquid plastic with unique properties that make it the ideal solution for improving traction on model railroads, slot cars, and numerous other quirky little problems left to your creative fertile imagination.
Using a toothpick, apply one or two drops to a rotating driver (power the belly-up loco). BULLFROG SNOT forms a thin, very grippy plastic traction tire, virtually invisible after it cures. Allow the wheels to continue to turn as you watch BULLFROG SNOT cure, let the laws of physics create a nice round tire. Apply just enough to evenly cover the surface with a thin coat - too much makes a mess. Let it cure overnight, or at least several hours.
Rubber O-ring traction tires rot, wobble, and often fail when there's work to be done, and have been an inherent curse on N scale since the early days. They are not replaceable for most practical purposes, and they can't be adapted to slippery engines that were not factory equipped. Unless you are a mechanical magician.
BULLFROG SNOT was created and developed by an N-scaler to be a traction assist for N scale, but it applies to other scales and applications as well.
The properties of BULLFROG SNOT are ideal:
It is easily applied, and easily removed. Just a toothpick is all you'll need to install, an Xacto knife to remove.
It's ready to go - no multi-part mixing. No witches brew of acetone, RTV, buffalo glue, snake oil, belt dressing, two-sided tape, shrink tubing, chicken bones, eye of newt, or dilithium crystals
No disassembly, no special tools, no surgical skills
It cures at room temp in moments. No baking. No nasty fumes. It's benign and friendly.
It’s easy to see your work, and it cures to virtually invisible.
It is thin – only .0055" when cured
It's tough and durable. Has a good service life.
Leaves no significant residue on the track.
Universal - works for any loco from any manufacturer.
Most engines improve with one axle (two wheels) SNOT'd. Shelf queen steamers come to new life. Optimum placement and locations vary, so experiment! What doesn't work out is easily undone.
Yes, you loose some electrical contact, but most diesels and tender pick-up steamers don't have an issue. The trade-off is worth it.
And when it wears out, which it will, you have already provided for your re-tirement because one ounce of BULLFROG SNOT contains 100s of scale tires.
Keep BULLFROG SNOT from freezing and Kryptonite.
$24.95 is too expensive? Considering the alternatives BULLFROG SNOT is a bargain. But then maybe it's SNOT for you ....
at Amazon.com and eBay while
www.bullfrogsnot.com is under construction
(Back in my desert racing days we'd race, pull the engine, split the case, throw in the checkbook, race, split the case, throw in a credit card, and repeat ad naseaum. We sealed things with yellow 3M weatherstrip and adhesive we called "monkey snot")
