PrairieKnight
I have a question regarding track cleaning. I have posted in the past about the products I use to clean my track on the layout which is in the basement of my one hundred year old home. This location makes my Atlas code 83 track susceptible to a variety of temperatures, humidity levels, and the ever present combination of dirt and dust in the basement. Track cleaning is a part of the hobby just as are operations, scenery, and modeling rolling stock and structures.
I use an old cotton T-shirt to apply WD-40 Contact Cleaner or Ronson Lighter Fuel to clean track with good results. However, I would usually clean the track while the layout is powered up and a locomotive is moving rolling stock to or from one of the industries from the yard. My son will be running the NCE system and when a locomotive points out a section of dirty track, he stops the locomotive and I use the T-shirt and one of the products I mentioned above to clean the dirty track. After we run the locomotive over the problem section a couple times without a problem, we continue with our operations.
I am working on ballasting the track. After ballasting a section of track I started cleaning track on other sections of the layout using the T-shirt and products I mentioned. The track is obviously not powered as the ballasted section needs time to dry and firm up. Is it just my imagination... or.... does it make sense that cleaning the track with the power off is resulting in less black gunk on the rails and a lot less stops for track cleaning during operating sessions. Because that is what seems to be happening during our operating sessions since I started ballasting track.
I know that many folks have track cleaning cars that are obviously putting cleaning solution on the rails while trains are running. But perhaps the products I am using attract dust and dirt when applied to a powered track. Any thoughts?
