Ok, I looked it up (I probably should have done that in the first place
), Tony's Trains says:
A 1K (1000) Ohm 1/4 Watt resistor will work. If space is tight use a 1.5K 1/8 watt resistor.
When using 1,000 Ohm resistor with 14 volts DC at the Function Output Common, there will be at maximum .0125 Amps or 12.5 mAs to flow through the LED. While this is less than the desired specified current for the LED, it will give plenty of light and the brilliance is only marginally affected. You won't notice the difference. Operating at the lower current, allows for a higher voltage at the track that some DCC systems have, mainly the Entry Level systems.
But, that is for regular sized LEDs. I'd imagine that the surface mount ones would draw the same if not less power.
Also,
Using 1,000 Ohm resistors with your LEDs, as I do, the heat dissipated is .0125 x .0125 x 1,000 = .156 Watts. A 1/4 or 1/2 Watt resistor is suitable.
Two similar value resistors connected in parallel, make a resistor HALF the value of each resistor with TWICE the wattage. E.G. Two 1,000 ohm 1 Watt resistors in parallel makes a 500 Ohm 2 Watt resistor.
So, when I do the install, I'll see how much space I have. If I can fit a 1/4 watt resistor, I'll go back to Radio Shack and exchange these 1/8 watt 1K ohm resistors for 1/4 watt ones. If a thicker 1/4 watt 1K ohm resistor won't fit, I'll use two of these 1/8 watt 1K ohm resistors and hope that 500 ohms is enough.
EDIT: Doing some calculations with an online calculator, it seems that the SMLEDs run at 15 milliamps, 3.4-3.8 volts, so 1K ohm is about right, but I'd need 1/4 watts to be safe for a resistor. Hopefully the 1/4 watt 1K ohm resistor fits!
