Boy am I getting confused???
I have seen layouts with the track on cork roadbed placed directly on the bench top!
What do you guys use to fix it to the bench top?? glue rail to cork and cork to bench?? what glue??
I've read about the use of foam, I assume , styrene?. Is the track and cork mounted directly onto the foam? and how?
My proposed layout has a 2 1/2 percent grade, I only intend to use short trains so it shouldn't be a problem, do I use the foam to create the grade?? or is it only used for scenery??
How do I cut the foam??
HELP!!!
Mac
HELP!!!
Mac
