Trucklover
BNSF SD70MAC's
Im hoping someone can help me out here, i just got 14 Roundhouse 5-bay Rapid Discharge Hoppers lettered for CSDU and CSDPU, and they all have metal weight frames that "lock" into the under body of the cars. This is where the holes are drilled out on both sides for mounting the trucks and the coupler covers on, only there not nearly deep enough and i can only get the screw to turn like once around in the holes before they stop dead and will not turn anymore.
The screws they come with are not very long to begin with, 5mm long flatheads. Should i get new screws for each of these? How can i fix this problem? Am i going to have to drill out each of these holes? If so, whats the best way to do this? Tap and dye? What size whole should i drill them out to if i have to do this? Again its a metal frame these wholes are in, so if i have to re-drill/extend the holes, i would have to have to go through metal.....
Any help is appreciated, and thanks in advance.
