Hi Guys,
I'm new to model railroading and to this forum. Here is my question.
I am building a wall train in my kids room. (see pics). It's a work in progress I know, but anyways, I have wired a bunch of lamppost and building lights around the tracks I have up thus far (est. 10-12 lights thus far).
To make it easier for my kids to turn the lights on and off, I brought a toggle switch from Home Depot and built a box around it. The toggle switch specs are 10 A 277 V AC / 20 A 125 V AC / 3/4 HP 125-250 V AC. Now I'm not electrician and have no idea what all this means.
I'm powering the lights with a cheapo tyco transformer (as you can see in the pic). The specs on the transformer is rated at 7 VA Max Output and 18 V AC. I have the wire for the lights connected to the switch, which is then connected to the transformer.
Here in is my problem. The switch works perfectly when I initially plug in the transformer. I can even leave the lights on for an extended amount of time (so far just tested about 20-30 min). However, when I turn off/on the toggle switch, I can hear a click (sometimes) and then nothing. The lights just go out and don't come back on. After I unplug and replug the transformer, then the lights come back on. I assume it's some sort of safty feature engaging. How do I prevent the lights from going out and having to replug everything?
Any help or suggesting would be appreciated.
Thanks.
Rod
Thanks.
Rod
