jbaakko
Diesel Detail Freak
I can't decide, there's to many options for turnout control.
My current thought, is to use modified Caboose throws on the "branchline" switches, and Blue Point machines on the mainline switches. Does this sound viable?
- Caboose Industries throws, but the over scale issue is annoying. I might be able to modify them to look like modern hoop handle throws however.
- Then there's Blue Point machines:
http://www.ppw-aline.com/Blue Point Manual Turnout Control.htm
I might use them on the few mainline switches which in reality would be power switches anyways. I'd use manual push-pull throws on the fascia (is that the right word?). This works great on some of the modules, but a few of the switches will be blocked by the lumber framing underneath.
- Proto:87 stores carries a nice hand throw, though it would require a more complex set-up on the fascia...
http://www.proto87.com/turnout-controls.html
- Maybe use a lever from CTC parts, in conjunction with the 90 degree turn part from Proto:87 stores? The CTC lever would push-pull on a rod, connecting to the 90 degree turn part, which would then connect at standard 90 degree angle to the track.
http://www.ctcparts.com
- I just read about using a slide switch embedded in the layout, as a sliding switch actuator. Again, this works great, minus the mainline... The rod connects through the plastic slide, when you slide the false stand, which would be connected to the slide switch, it switches the turnout...
- ANE Model has a nice servo operated switch idea. The cheap kit is $20. This would allow for power switches. Little costly however.
