NYSW F45
I have 6 frames that I need to have certain area's milled down due to clearence issues. All are railpower products frames.
2 SD90Mac frames. Finally got those rubber motor mounts trimmed enough to fit the motor, but the trucks have almost no clearence to rotate if the side frames are on. I want to mill/shave off a tiny bit of the underside of the frame to give the trucks w/side frames enough clearence that they wont rub and cause steering issues.
3 C40-8W and 1 C44-9W frame. The engine mounting in the fuel tank is to high, wayyyyy to high. I want to mill it down so I can mount my RTR motors. I can mount them now, but the shell will not go down with decoder installed. Not even close. It sits atleast close to 1/8-1/4 above the frame.
Where can I get something like this done?
