jacon12
If you'll note in the diagram below, I've set aside the spot for my passenger station in a difficult spot for my passengers to get to without getting killed. From the bottom, come up halfway on the bottom row, then come over 7 (large) blocks from the right, the area between the yard and the 'passing sidling'. That green area between the yard and the mainline is where I'd planned for it to be.
My passengers have no way to get to the station, I don't see a logical place to bring in a street or road to it without crossing several tracks. To complicate it further, the yard area will be two inches higher than the area where the passenger station would sit. The track directly in front of the station and the siding for the passenger train is at 0 elevation. Getting on deeper, the siding for the passenger train is ACROSS the mainline from the station, so they not only can't drive down to the station but they must risk getting killed crossing the mainline.
One solution is to move the yard forward on the bench and put the passenger station on the back track (swap them in other words, then the yard would be closer for switching and uncoupling etc Plus I wouldn't have to build up all that area to 2 inches where the yard presently sits.
That make sense to you?
I'm open to suggestions please.
Jarrell
Jarrell
