CoolRuehle
I am a member of a local HO model railroad club and they have a modular layout as well as a permanent that is under construction. All track is code 100.
My home layout is mostly code 83, with 70 on some industrial spurs. I have a mix of Walthers slag, hot metal, and coke cars, as well as Athearn bluebox tank cars, and offset coal hoppers.
From my research, there are basically three different types of wheelsets in HO. We have code 110, code 88, and then Proto 87 to choose from.
In all, I need about 150 wheelsets as most of my rolling stock have plastic (shudder) wheelsets. I do not like the look of the code 110 wheels, the treads are just too wide to my eye. The code 88 look right, the Proto 87 look to skinny to my eye. I just want something that runs great and looks semi-scale. The 88s look like they will work for me.
I am sure the 88s will run on my home layout. I am careful about my trackwork. At the club, the permanent portion of the layout is similar to mine at home. It's the modular that worries me. It's not a high quality setup because of the difference between each modeler's skill levels, and the fact that it's packed up and run all over the place many times a year.
So my questions are these:
1. Will the 88 wheel sets work on code 100 track that has not been laid with the best of care?
2. Will a Kadee code 88 wheelset fit both the Walthers and Athearn trucks (width)?
TIA!
--Jon
TIA!
--Jon
