Siccmade said:
What is the best and cheapest way to make my river and lake water look real?
This is one area I want to get a whole lot better at. For now though I did it the simple way with Woodland Scenics Realistic Water, some blue and black acrylic artist paints and multiple redo
For a starter, you want to make sure you have an inpression in the scenery that your want the lake or river at. You want to be sure that it's sealed well. I know some use plaster and smooth it, I used WS Foam Putty. Once I have the lake bed the way I wanted the contours to be, I mixed the black and blue together and made it more black then blue. Then paint in your lake bottom. Once it has dried, I then poured a very thin layer, let it dry for a day or 2, then pour another layer. You can pour as many as you want, but it really doesn't seem to help with the illusion of depth.
Like I said, mine is okay, and as I get more time I may redo them, the beauty of WS Realistic Water is you can pull it back up after a while if you want to redo it. Joe Fugate should be addressing lakes and rivers in his Scenery Clinic soon. He has some very realistic water effects. Hopefully others can chime in with some more professional results.
