modelrailroadforums
I purchased a relatively inexpensive 4x8 foam/plaster of paris (?) layout with two tunnels, raised track etc. Yes - doing it from scratch probably would have been better, but I don't have the time, nor patience.
It needs quite a bit of work to get it to the point for painting, scene construction, etc. There are components that need support as they are spongy. Other parts need thicker plaster of paris or whatever it is that is used to form the hills, city underlayment, etc.
Some questions:
1. I was thinking of adding a bit of expanding foam (used at home to fill cracks, insulation, etc.) underneath those areas that need support. Any better product? The foam, if inserted modestly, will probably do the job, but....
2. The plaster of paris that was used over various cloth elements of the layout needs more layers. I could simply go with plaster of paris, but suspect there's something more professional. What I would really like is something sprayable.
3. Are there any sections on this site that have escaped me that would be a good overview of scenery construction?
Any help would be appreciated.
Some questions:
