mtrpls
Ignorance is Patriotic
Hello everyone,
I have a major problem and I am frustrated to no end. I have spent the last year or so assembling a unit train, 60 cars to be exact, using Eel River Models' (ERM) 62' beer car. Finally, the other day was its first test run at a local modular layout here in Denver.
Much to my dismay, the 60 car train wouldn't stop uncoupling and disconnecting; when I backed the train up to pick up some cars that had uncoupled, the problem worsened. It seems that every time I go in reverse, then move forward, the train will uncouple in several places and segment into 5 or 6 pieces. Every time the train begins to move after being stopped, or after being put in reverse, the grasp between the Kadee couplers is lost. What's more, when I use my hand to move a string of cars that have fallen off the back of the train, the cars that I move will uncouple and another piece of train disconnects. When I move yet that other string of cars, lo and behold, the last five cars uncouple and the train is literally in five or six separate segments. Simply put, I can't keep this train together as it travels over the layout.
I am using Kadee #26 couplers, as per the instructions on ERM's 62' beer car. ALL OF MY COUPLER HEIGHTS MEET EXACTLY THE NMRA HEIGHT USING THE KADEE HEIGHT GAUGE. THE COUPLERS ARE CENTERED USING THE CENTERING PLATE. I have hundreds of freight cars using Kadee 5's, and have never had any problems. I can run 100-car trains of my other rolling stock with no major uncoupling issues; as I mentioned above, all of my coupler heights are standardized. Using Eel River Models' beer car, and using Kadee #26 "long shank" couplers, this 60-car unit train is in a complete mess, the train will not stay together and seperates at every chance it gets: when moving forward (picking up slack) after being stopped or put in reverse, at slight curves, etc.
The uncoupling issue does not seem concentrated to a few specific cars, the problem is affecting all 60 cars randomly and frequently. I have inspected all cars several times, and the coupler heights are standardized and the coupler efficiently centers using Kadee's brass centering plate.
I have provided the following graphical timeline of the issue, step-by step. Let's start with STOPPING THE TRAIN, THEN MOVING FORWARD...
Step 1: The train is stopped, at a complete standstill. The train them moves forward. Instantly, the Kadee couplers lose grip with one another when the slack is picked up:
The train is uncoupled. When I move the string of cars to reconnect to the train, another uncoupling occurs 5 cars down the line, in the same manner.
Let's now put the train in reverse to pick up some uncoupled cars, shall we?
STEP 1: Here we can see the couplers being compressed, shoved together, as the train is being pushed in reverse:
STEP 2: Now we move forward. As slack is picked up, we can see the "claws" of the Kadee couplers are not meeting in a gripping manner. Sometimes they decide to "click" inward and re-establish a bond, but most times they decide to fall outward, losing their "handshake" so to speak. This is clearly going to happen here:
STEP 3: Slowly, as the train is moved forward, the couplers decide to part ways...
The train is uncoupled and, as I look back to the end of the train, I notice uncouplings at several places throughout. The train is now in 4 or 5 pieces...
CAN ANYONE TELL ME WHAT IS GOING ON HERE? These couplers should be in perfect working order, but this uncoupling problem is so pervasive and happens so frequently that I am about to give up on this train.
The only explanation I can conjure is that there's something peculiar with the physics of the car and the #26 coupler, a problem with the design of the car, or placement of the coupler mounting bolster at a certain measurement so as to exploit a vulnerability in the #26 coupler's operation.
Assuming the "long shank" couplers contributed to the problem, I attempted to outfit some cars with a standard #5 coupler, but they don't work due to the car's design. ERM placed the coupler bolster, or mounting pin, recessed too far back into the coupler pocket to accomodate a standard shank coupler; a long-shank coupler such as #26 must be used just so the coupler can clear the end of the pocket. Looks as though I'm stuck with the #26's, but this is not working. This train will not stay coupled together.
I have debated using shelf couplers, such as those used on tank cars, to not only assist with this uncoupling problem, but also to help me solve uncouplings due to vertical shift as cars rise and fall over uneven trackwork and between modules. Question is: does anyone make a "long shank" shelf coupler?
I've thought about using dummy couplers too, but again, not sure if anyone makes a long-shank version that will clear the edge of ERM's coupler pocket. Another drawback to dummy couplers is that I would like these cars to be compatible with other rolling stock using Kadees, McHenry's, et al.
I don't know what I'm doing wrong, guys. These 60 ERM cars have passed vigorous coupler inspections, and exactly meet standards in every way. Theoretically, this train should work and remain coupled, but it breaks apart into several segments so easily; the slightest jar will cause several uncouplings throughout the train.
Can anyone offer advice or direction as to where I need to go with this project? Thanks for any help, and apologies for this LONG posting. Can you tell how frustrated I am?
Your friend and fellow Model RR'r,
Matt
Matt
