Hey Der Folks,
Wish me luck, on my first Craftsman Kit build. It'll be slow going I'm sure, but I will post updates has I work on the kit. I do plan on setting the completed kit on a small diorama.
Certified Great Northern Nut
If I can do it, you can do it!
looks like your well prepped for it
Looks like one of Focale’s kits. That one is pretty easy. Just take your time and read over the instructions a time or two before you start. Measure twice, cut once.
Started to cut out the pieces, and lightly sand the sides. I am using the "scrap" pieces to experiment a bit, seeing how the wall pieces come together with bracing, also going to test my wash, and try lifting some of the board siding before moving on to the actual kit.
Hey Der Folks,
Completed the bracing pieces, and did a "test fit". I surprised myself that all the corners match up nicely (just had to do a tad bit of sanding). One thing I did notice is that some of the bracing isn't exactly square, glad I noticed it and was able to adjust. Next up, A&I wash, and paint.
Question: Has anyone used an airbrush for painting the kit? How does it compare to brushing? I am using Badger Model Flex Antique White. I also have Folk Art Vintage White.
I've been doing a mix of rattle-can enamel and acrylic brush painting on my kits. I used my airbrush with acrylic paint for one build and it worked out fine. I just don't like cleaning the airbrush when I'm done.
I recommend color AI washes for wood kits (be careful of warping). I posted this in another thread, as this was done with all AI washes:
Her Der Folks!
Added the A&I wash to the main structure. Next up, I will be adding the main color, and also paint the trim, windows, and doors. Not sure if my wash is too dark (it looks darker in the picture than in person). I plan on doing Antique White on the main structure, with POLLY Scale C&NW Green for the trim, windows, and door trim.
-Steven
Hey Der Folks!
I airbrushed the walls with Antique White today. Next step, I will be adding the sign, doing some highlights, and add some weathering. Then, I will be moving on to the trim, windows and doors.
-Steven
That is coming along nicely!
Hey Der Folks,
I added the Windows, Doors. and Signs, next up I will be adding a few more signs and (the part I am dreading most) doing the weathering. When it comes to weathering, I understand less is more, and to work in multiple layers.
-Steven
Wow, that's looking great! That big sign looks painted on, how did you apply it?
Weathering is something I'm working on getting right also.
I lightly sanded the back with 220 sandpaper, and I attached the sign with 3M Transfer tape. I applied the tape to the back of the sign, then I trimmed slightly into the black, applied to building, and used my fingernail to push into the clapboards. I since lightly sanded the sign (pictures coming soon).
-Steven
Well it turned out great! I'll have to remember that way of doing it.
Hey Der Folks!
Well, I started on the weathering, can't say I am completely happy with the results. Please understand that this is my first attempt, and I knew I would not get the best results. The key thing is, I am learning a lot, and I am having FUN!! I been taking notes on what is working, and what is not working. I do plan on continuing with some subtle layers, and try fixing some of the details I am not happy with. Next up, I will be adding the window and door "glass", assemble the walls. and add the roof.
-Steven
I think it looks pretty good. Just a general dingy dirty look. I like the darker areas at the bottom where the snow piles up in the winter.
I also like your weathering, think it looks quite realistic for an aging building.
