So I am the proud owner of my first Athearn genesis engine with the Tsunami decoder. Well mostly proud. Was annoyed when I did a test run and heard some odd noises coming from the front. Took it apart (broke off a few details pieces in the process) and found out a piece of the from gear assembly was missing. Luckily I had an old engine that I could grab parts from and was able to fix it. A bit disappointed since it was a brand new engine.
Anyway my main question is I have a DT100 throttle (only functions 0-8) and I haven't figured out how to get the decoder to make the engine shutdown sequence sounds. Also the minute I power on the rail the engine goes through startup and then idles.
So, if I were to have (which I don't) many of these on my layout some sitting in engine terminals. How do you get them to sit there and be quiet and only make noise when you actually intend to use them. Second when I'm done how do I park it and have it go through the shutdown sequence.
