I don't really understand anything about decoders and setting CV's and such , so I figured I would just ask those that do understand , my questions. I have a Bachmann 2-8-0 that is decorated for Durango and Silverton RR and the slow speed performance is poor . I figured it might be when I bought it but the DSRR is only 45 miles from me so its my local RR and I just figured I should have it . Anyways , if I change the stock decoder ( no sound) with a better decoder , will that improve loco performance at slow speeds? If so can anyone recommend a tried and true decoder? I don't need it to do a lot of things , as I said , because I don't really understand how to take full advantage of them and it doesn't have sound , but I would like something to better the control if that's possible .
So after I test run the Bachmann , I thought I would set up another 2-8-0 I have . Its a BLI . I set it on the track and got nothing ( I program on the main with an NCE system ) There were no other loco's on the track . I read through the manual and it said that I should reset to default and try it again . My choices were to set CV 8 to 8 but I don't know how to do that . My other option was to pull the tender body off and press a reset button while turning on track power . That I could do , so I did . The book said I would hear some sound when the reset took place . It never made a sound so I powered down the track and tried it all again with the same result . The loco did nothing , no sound , light , movement , just totally dead . Would this mean that the decoder is bad ? Thanks for any help you can offer.
