Well Joe,
In N scale there are indeed many choices of track available.
If you are running older equipment (with larger flanges) your selection will be limited a little. Running DCC will cut the field a little more.
Basically it breaks down like this (or so I understand);
Atlas code 80 - the old standby. It's bullet proof, cheap, easy to find, and DCC friendly. It just doesn't look the greatest (tall rail, oversize ties and tie spacing and so forth). If you don't mind the looks, it is OK. Good ballasting work, painting and weathering the rails can help a lot with the looks.
Atlas code 55 - Looks good, pretty easy to find, decent price, DCC friendly. They offer wye turnouts, # 10 turnouts, and various crossings. Problem is, older equipment has larger flanges on the wheels and they hit the ties on this track. This may not work for you. If you're buying currently available equipment this will be less of an issue for you, except with Micro-Trains cars. You'll have to get low profile wheelsets for those.
Peco code 80 and code 55 - Great stuff, lots of track choices (curved turnouts, Stub turnouts, slip switches, and all kinds of stuff), solid and reliable. The code 55 is really code 80 track with a double flange on the lower sides and it's buried in the ties further. It doesn't have any flange issues so you can run older and large flanged equipment without worry. Problems - wide tie spacing (European tie spacing), expensive, tough to find in some areas, and some say it's DCC friendly while others say no. I think proper guaging of the wheels of your loco are quite important with this track, as the spring mecanism on the turnouts can cause shorts if the wrong wheels touch the wrong point rail. The spring in them snaps the points of the turnout closed and holds them to the rails. I've been told one solution is that you must remove the spring and make a new throwbar in order to use DCC with no issues. I'm sure someone will correct me if I'm wrong on any of this. One last thing.....turnouts are expensive, but they are not only DCC friendly, and they also have built in switch machines.
Micro Engineering - Awesome looking track. Problems - turnouts have a spring like the Peco ones so it has those same issues, can be hard to find, very expensive. Great track available in weathered or non-weathered in code 70, 55 & 40. They also offer bridge track or the rails and ties seperately if you want to spike your own. Turnouts are only offered in #6 though.
Kato - easy to use, easy to find. Problems - not much flexability (no flex tack), expensive. This stuff is DCC friendly.
Bachmann EZ Track - about the same as Kato, but has a high track profile and it's not the best constructed stuff in my experience.
Model Power - Don't bother with it as it falls out of gauge easily. Great source of headaches if you're looking for one.
Shinohara - Code 70 turnouts and other code 70 products. I have a code 70 3 way turnout and I've seen a code 70 double crossover (works of art!).
Arnold - Not worth the time or money if you ask me. Expensive and not realistic looking.
BK Enterprises - Makes parts for handlaying track and offers some assembled turnouts (curved, stub, wye, and regular) and crossings. Offers a code 70 #12 turnout and code 55 #12 turnouts. Offers code 40 products. I have no experience with this product so I'll refrain from comment.
Life Like - Much the same story as the Bachmann track.
Roco - Extremely limited selection and not very realistic looking IMHO.
That's all I know of. I looked at almost all of these when beginning construction on my new layout, and personally, I chose to use Atlas code 80 for all my hidden track and Atlas code 55 with some Micro Engineering code 55 bridge track thrown in for good measure on the bridges of the layout.
Now since Micro Engineering just came out with a DCC friendly version of their HO stuff, N scale might be comming soon.
Check out this link for more info as to DCC issues. The main subject is HO scale, but most of it also applies to N as well.
http://www.wiringfordcc.com/
