TomC:
I agree with Selector about plastic insulated rail joiners.
Here's what I've been doing for the past 17 years and why.
I ALWAYS use a Dremel tool with cut-off disk to make electrical gaps (on straight and curved rails, and even on the running rails in the middle of track switches.) In my experience, one way or another the insulated rail joiners, especially on curves, WILL cause the two rail ends to mis-align thereby causing derailments. And they don't have to mis-align very much.
I use all Atlas Code 100 flex rail in 3' sections. When laying track, after soldering the rail joints and dressing them up (making sure they are smooth), and have secured the track to the roadbed, I mark the first electric gap on one rail with a pencil mark, then go across to the other rail, go at least two tie spaces left or right of the first mark, and mark this rail. If you use flex track MAKE SURE THAT BOTH PENCIL MARKS HAVE PLASTIC BETWEEN THE TIES UNDER THE RAIL - the flex track tie strips have crosstie connection gaps every other tie on one side - for flexibility.
The next step is get out the Super Glue and put a small drop on each spike/rail connection on both sides of each rail out to 4 ties on each side of the mark. Let it dry/cure. This makes the rail/tie combination stiff.
Use the Dremel tool to cut the gap on the pencil marks but do NOT cut through the plastic tie strips under the rails. (Note: With my Dremel tool and cut off discs I have to cut the gap at an angle; no big deal.) Use a small file or the Dremel tool cutoff disk (at slow speed) to dress/smooth the rail ends at each gap.
As info I've never had to fill any gap to keep it from closing.
And by the way, I've done this method on pre-made sections of curved track. It's easier than flextrack - the plastic tie sections are all rigid.
I know it's a lot more work than using plastic insulated rail joiners, but when using the method described above the gaps are basically maintenance-free (they do not cause derailments) and practically invisible.
I guess I've got over 40 rail gaps made by this method, and in 17 years I've had one failure.
Hope this is helpful.
DougC
