A 'hoistable' layout seems to be the way to go for a garage, unless you're planning on parking a van or SUV under it, in which case you may have some clearance issues (or a new and unexpected skylight). However, if you have a car that won't have any clearance issues, I think it is the best compromise. A hoistable layout would allow you to do some more scenery, although again you will be limited by how far up you will need to hoist the layout (unless you have 'dead' space above the garage ceiling, and you can build a 'box' above for the layout to live in).
Red Oak & Western said:
What I would suggest is designing the layout so that it hoisted up to the ceiling, similar to many bicycle storage systems. A series of ropes and pulleys connect to the corners of the layout and raise it when the ropes are pulled.
I would guess that through a series of pulley/rope assemblies, you would be able to use just one rope to simultaneously lift/lower all four corners of the layout. It'll probably take some trial-and-error construction and adjustment, but it is definitely do-able.
CBCNSfan said:
Hi All, well there's one more possibility we haven't looked at yet. What do you think about an 4' X 8' suspended from the rafters. When not in use it could be raised into a cover (box with a dust seal) attached permenantly to the rafters. The supporting cables could be counter weighted, and in the down position the layout could be supported by legs of some sort. Although it would be heavy, one person could raise and lower it easily and not worry about damaging the scenery.
How about attaching a set of folding legs directly to the bottom of the liftable benchwork? Foldable legs for 'banquet' type tables are relatively inexpensive, and won't add too much weight either. That would save having something else to store, and would probably be easier to use too (simply partially lowering the layout and then flipping down the legs would probably be easier than having to position separate legs while someone else lowers the layout onto them).
I have zero experience building layouts, so keep that in mind
, but I've been rather interested in this thread and figured I'd throw my ideas in as well. I'd like to construct a similar 'contraption' in the garage, but since college is only a couple years off, it doesn't make much sense to start now
