Appreciate it, thanks!It sure would. Nice panel, I'll have to keep it in mind.
If I remember correctly, the tortoise switches have dpdt switches built in. It's been a while so I could be wrong.umm just my 2 cents the tortoise needs a DPDT toggle those that you picked are SPST
pdf instructions from curcuitron http://www.circuitron.com/index_files/INS/800-6000ins.pdf
There are three basic ways to wire tortoise machines. Yes, these will would work if you are using an AC power supply and diodes, or if you are using a full dual DC supply (plus, common, minus). No, It will not work if you are using a standard single DC supply (plus minus). This last way, as the others have said, would require DPDT switches.
