I concur with Bob that while DCC may appeal to many of the newcomers in the hobby, DC will work just as well and decidedly more cheaply in many, if not most, situations and is far from a necessity.
Too often the fiction that you need DCC to run more than one locomotive at a time is posed by DCC enthusiasts as THE justification for not only starting out in, but the absolute need to convert to, DCC. Well, I've "operated" on my modest-sized (13x20) layout for years using DC, running multiple lash-ups without difficulty and finding it no inconvenience in occasionally needing to flip a few toggles. NYW&B
While I would certainly agree that an established layout, a large roster, both DC, and a happy owner are all excellent reasons not to convert. I also think a little clarification is in order on a couple of your talking points: NO, you don't need DCC to run more than one loco, and I don't believe that anyone has ever said that, at least here. YES, DCC does make it easier, not necessarily with two GP-9's, but with dissimilar power like models from different manufacturers, or different loco types, such as a low drivered 2-10-2 assisting a high drivered 4-8-4 on a passenger train in a helper district. DCC makes speed matching a consist like this easy, while it is not really possible with DC.
While DCC certainly has benefits for the truly large layout that regularly employs multiple operators (I "operate" monthly with an 6-9 man crew on a friend's very large DCC layout), probably 95% of hobbyists today still run their layouts alone and it is honestly unrealistic to expect one man to run multiple trains at one time (except on independent loops of track, just as easily done in DC) and remain fully in control.NYW&B
Agreed, except you could set one train, say a passenger, to run continuously on a loop, then operate a local peddler freight and have to stay out of the passenger train's way while you switched your industries. This is an interesting excercise and you have a red button on the throttle to shut the layout down if you goof
I'd add that the cost factor of a properly installed DCC system on anything more that a fairly small layout costs many times what a similar DC system does. It is certainly not as simple as a two wire connection, as is often claimed. Most DCC applications will necessitate virtually as much wiring as for DC, plus the added expense and installation of power district boosters, plus the isolating of layout segments as with DC. Add to that the large expense for established DCers of purchasing decoders for their existing locomotive rosters and we are talking costs running into the thousands of dollars to convert. Not surprisingly, many established DCers are sticking with what they already have.NYW&B
Love to see how you figured the costs on this, because that's not necessarily the case. I could probably convert your entire 13 x 20 layout with a single command station/booster combination, and at most something like the Digitrax PM-42 that lets you split the layout into up to four power districts. Auto reversers are cheap now (20 bucks or so), and you won't need all those toggles or extra wires either. The cost difference is not as much as you think. The next benefit is, if you have guests over to operate, you don't have to give lessons on what switches operate what blocks, where the reversing sections are, and so forth. Form DC layout to layout, this is always different. Most DCC systems are pretty user friendly, and easy to get the hang of, and all the toggle switches go away.
Sound is also touted as some great benefit of DCC. However, all the really necessary basic train sounds are operational in DC today. And many of the additional sound features in DCC locomotives in my opinion are beginning to approach the "playing with Lionels" level, especially things like supposed engineer radio communication. Ugh!NYW&B
YES you can have sound without DCC, but with DCC, you get the most use out of it. You take full advantage of the capabilities of the models and gain many things that DC users are locked out of. Even the "black boxes" available from MRC and others don't let you use everything that's there in those decoders.
I am with you totally on some of the sound model features though. I don't care for talkies, puffing smoke or other circus sounds showing up in some of todays models. Those are for the three rail crowd. Even lit passenger cars aren't very high on my list. If they come that way, fine, but I won't pay anything extra for the capability
If you are a true newbie in the hobby, then perhaps starting out with DCC will have its benefits down the line, but DC is definitely here to stay for probably much of the next generation. In fact, it isn't likely to fully disappear until DC, along with DCC, are made totally obsolete by on-board battery power with radio control, perhaps a decade, or less, from now.
NYW&B
I've often heard the statement "I have too many locos to convert, it isn't practical, I'd go broke!" Then, about once a month, these same guys are posting the latest loco they just bought. It isn't about how much money you have to spend, it's about where you want to spend it. We have faced the same problem on a smaller scale with other issues, like that first conversion to all metal wheels, or for the older guys (including me
) converting to Kadees. Then too, how often to those 200 locos get run? I have an embarrasingly large roster myself, with many models slated for DCC conversion down the road, but only about 10-15% of the roster sees regular service, so it isn't like you have to go and buy 200 decoders all at once. Eat the elephant one bite at a time.
I agree that DC is not ever likely do disappear, but the option is likely to get more and more limited, no matter which system you favor, because the market is going DCC. It's what the manufacturers are doing, and they are following the money. Most modelers want DCC these days, though we don't want to take your DC away. If you're happy with it, by all means keep it, after all, this is supposed to be fun!
