I have a A-B-A set of F7's that are currently standard DC. I want convert one of the units to DCC/Sound using a Tsunami and the rest will be DCC only. The problem I am running into is I do not know enough about lighting and what Tsunami board to buy. The Intermountain F7's have LED's for lights, one for each numberboard and one for each of the double headlights (4 total).
I think I should either get the AT1000 or the GN1000. I would like to avoid using resistors as I am not that great at soldering. I can manage the connections to the board but beyond that is a challenge. Will the 1.5v lighting outputs on the GN1000 work with the LEDs without issue or do I need to use resistors. Or should I look at the AT1000 board? I am pretty confused and would appreciate any help.
Matt
Matt
