Running Bear's Coffee Shop XLVI
Unfortunately no, but I think the answer is on Microsoft's Support Site FAQ, under disabling IE. Apparently many people want to disable it. I have no doubt it's still there as a hidden file somewhere within the Windows code, but it won't show up as an active program, or update.
Now, if I can only identify and purge some of the other background stuff that eats processor capacity and memory.
Click the start icon, and enter "msconfig" into the search field. MS Config will come up in the search area, click on it. You will get a popup window with startup and programs tabs. Select each of those two tabs, and uncheck the stuff you don't want to run, unless you want it to. Click "exit", then "restart".
And if that doesn't turn off the stuff you want, go to "services.msc", and you can turn more stuff off and disable it from there.
Are you talking about the ones that came in the early Proto kits, or the really old/train set stuff? The Proto trucks are okay, I like the rib backs on the chilled wheelsets, but that doesn't look right on modern stuff.
I don't want to say "really old" lets just say Life-Like of Baltimore, circa 1970s, made in china Taiwan or Hong Kong, I don't remember which.
The reason I ask is I want to replicate the HO trains I ran under my Christmas trees. I had Life-Like 100 ton Chessie/B&O hoppers and a Life-Like Chessie/B&O GP38-2 followed by a Life-Like Chessie/WM caboose. Just like the trains I worked on when I was a coal sampler. They never gave me any trouble until the locomotives would fail.
I bought a Bachmann DCC GP38-2 Chessie/B&O locomotive to replace the Life-Like locomotive. I restored several Life-like locomotives and they run great, but I saw the new Bachmann and I wanted it. I could not find a new alternative to the 100 ton hoppers. I did find a Bachmann Silver series Chessie/B&O caboose, but it's still in the box.
I only want to have it run a few times around a simple oval of track under my little Christmas tree I set up on my layout. I bought a pack of Life-like knuckle couplers and replaced one of the old couplers to couple to the locomotive, worked great, but the cars derail. I checked the wheels and they seem like they have too much rolling resistance. I cleaned them with mild soap and water and it worked better but still would derail only less often.
Last Christmas (2013) I ran one of the Tyco spirit of 76 locomotives I restored and the Tyco cars from the spirit of 76 set (my first train) and it ran flawlessly every time with no trouble. It did not derail even once. Everything was all original on those cars but these Life-Like cars have not been as cooperative.
I am thinking the plastic has worn in the bearing either on the axels, trucks or both. If I am not mistaken they were made with some kind of slick plastic that does not need oil. I was thinking metal wheels and a little liquid bearings synthetic oil might get me through the dozen or so times I run it for maybe a total of 3-4 hours during the holidays.
By the way the Bachmann locomotive is fantastic and drags the derailed train until I notice it. I turn the Athearn DC throttle a little bit and the train will creep along. I had never seen a DC powered locomotive move so slow and smooth. The new plastic Life-Like knuckle coupler and the old horn couplers don't uncouple. even laying on a 45 degree angle being dragged along the track. It's only a total of 11 cars including the caboose.
I don't want to spend more money than I have to. I'd rather not change out the trucks, but if I have to I will bite the bullet and do it, if nothing else works.
One more thing; when did they switch to bath tube gondolas and stop using 100 ton hoppers on unit coal trains? I now live a few miles from consolidated coal's pier and I noticed they don't use 100 ton hoppers any more. I see the trains going over the bridges over Eastern Avenue when I pick up my boys from school. I love it here in southeast Baltimore. I can even hear the switchers working at the port when I am in my back yard.
As always thank you for answering all of my questions, I greatly appreciate it.
Louis, replace the standard shank Proto coupler you installed with an extended shank coupler on the engine. That way, it will have a greater swing area, and not be as prone to drag the first car off the rails.
Bathtub coal gons started in the 1970's and continued into the mid 1980's. Now, the standard coal gon is something like 120 ton capacity.
Good morning everybody!
32 with rain falling in south east Baltimore. The internet weather says it's snowing, but I know rain when I see it. It turned my front porch into a skating rink, but thank God I still have some balance and did not fall. The roads are fine except for the idiots, but I avoid most of them by going out early.
I am late this morning, spent the early morning hours with my beautiful wife. Then did my weekly Sunday morning grocery shopping.
Anyone have any predictions for todays conference championship games?
Terry I already know your answer ;) hmmm now that you know I am looking for the curve ball I am thinking it could be a fastball coming, but it will probably be a straight change. When I was young I could pick up the spin and see the curve balls coming a good change up is always tough.; I think you must have been a good pitcher, Gaylord Perry would be proud. Have you seen him lately?
Have a great day everybody!
I have not replace the coupler on the locomotive, I replaced 1 coupler on the first hopper, sorry for the confusion.
Either way the longer coupler on the locomotive will solve the problem?
I should have watched to see where it derails, but you very well could be right because all the cars are always derailed.
Good morning folks.
It's sunny and pleasant today. Almost makes me want to go clean the interior of my car. I hate this time of year where everything is dirty and wet. I guess the trade off is for it to get really cold and freeze everything!
I've started replacing some of the modeling supplies that have gone bad since I dismantled the layout two years ago. My rattle cans of rustoleum camo paint needed to be replaced. It's funny when I think how often I've used their paint. I use the brown to paint the track, sand for concrete roads and other stone surfaces, and black for structure roofs. I have an airbrush but choose not to use it for most scenery applications. I only pull that out for painting locos and rolling stock. I also found that most of my glue was bad and was out of xacto blades as well. Dang, how is a person suppose to model without the basics? A trip to Walmart and Michaels fixed me up.
I have to touch up the exterior brickwork paint on my brewery and then can start to glue in the windows. I'm actually quite excited to see what this looks like when it's done. Time to head down to the train room.
Have a good day everyone.
....... pitcher, Gaylord Perry would be proud. Have you seen him lately?
Funny you should mention him. My ex, Donna, met his wife while working at an antique when we lived in the rural western NC mountains. Mrs. Perry asked if she cleaned house on the side and would she come clean theirs - just the next town over from us. She did and came home one day asking if I knew of "some baseball player named Gaylord Perry"? Knowing her to be completely clueless about pro baseball I was puzzled why she would ask such a question but I replied "of course! How would be knowing about him?" Her response was "well, I just cleaned their house today. I met his wife at the shop and she asked me to come over." My jaw about hit the floor!!! She was still clueless asking who "this guy? They have trophies and pictures and baseballs in glassed in cases and stuff." I just said something like "GEE! YA THINK?!" And, "can I go with you next time they have you come over?". But it never happened.... alas.
Well, I decided to let the young cats into the train room to see what they did. They've been in there before but I never let them really check it out. FAIL!! It's just a little too much for them to handle!:) The combination of being up high AND having things to play with and eat sent them into crazy kitten mode. I'm sure they will handle it better some day, I just have to let them in there more often and they'll learn to not misbehave(wishful thinking I'm sure). The good news is that the touch up paint to the walls of the brewery is complete. I also installed all of the windows. I may start to erect the walls later, we'll see.
I haven't seen the Perrys since Fall, when I helped him get truck connected to travel trailer.
Somewhere around here, I have a photo of Gaylord and one of the salesmen. He's a pretty tall guy.
I do watch on occasion, when they show anything here, football, hockey, baseball and Nascar...
Football: Minnesota Vikings..
Baseball: Los Angeles Dodgers (should be Milwaukee Brewers, shouldn't it? ;))..
Hockey: Boston Bruins/Vancouver Cannucks..
Nascar: None..
Evening All,
I painted the Pennsy signage, weathered my box car, and for lack of a better term I dyed the outside edges of my gray track ballast. Because of how small the letters on the signs there is some slop in the gold paint. I think they look fine from a little distance. The "dye" consisted of black acrylic paint from Jo-Ann's. I mixed rubbing alcohol and water until it had a water consistency, then used a eye dropper to spread it. It looks good wet, so I am looking forward to seeing it dry.
52 degrees and sprinkling rain. I ended up not having much time at all in the train room this weekend doing way too many things, but I did finally find time to get this locomotive out of its box and give it a test run. I was really impressed. Years back I wouldn't have touched a Bachmann locomotive with a ten foot pole but since they came out with their Spectrum line I have bought a few and they were good locomotives. Excellent slow speed control and details to rival some brass locomotives I have seen. For $125 I won't complain at all.
attachment.php
Very nice gentlemen!
Can't remember if I posted this, if nothing else, it's well worth posting again... ;)
[video=youtube_share;Cy-ZUl8CbXE]http://youtu.be/Cy-ZUl8CbXE[/video]
I watched that a couple of nights ago and I agree, definitely worth posting. A lot of insight into many things that most of us never consider regarding the operation of a railroad. It's amazing how labor intensive most aspects of even mundane jobs were back then.
good morning everybody
36 with partly cloudy skies in south east Baltimore.
have a great day everybody!
