Running Bear's Coffee Shop XLIX
Karl ... Nice B&O caboose !
Phil, I think that is the Colorado & Southern.
Speaking of Colorado and Southern, here is a train order dated May 5, 1926 which may be interesting to some of you.
Good morning model railroaders. 28 degrees this morning.
BigE - Nice looking tower. Looks like time to find some more roadbed ?
The morning picture doesn't look nice. The result of a head on in Washington sitting in Milwaukee.
I've been replacing couplers on my engines and cars with Kadee #158 whiskers over the last few days while I convalesce from some minor surgery on a cyst (excised) on my back (going to take several more weeks before it can be closed up again). Most couplers have been straight forward (fiddly as usual for some) until I came to do the Athearn RTR 60' Gunderson high cube box cars this evening (latest release ones).
These are very fiddly and because there are no screws in the coupler boxes (only the trucks) and the coupler box lid is clamped between the underframe and the car body, there are only 2 ways far as I can see to get them apart. To make things a bit more difficult there are brake "rods" resting against the underside of the inner axle, but also at each end the coupler cut bars, which are fixed. glued?) to a bracket on the corner/s of the car body, the thin end of which rests against the underside of the coupler box, more or less, trapping it in position.
My first 2 attempts I loosened the truck screws to allow the ends of the underbody bracing (which the coupler box is a part of) to lift up enough to get the lid off and the plastic coupler out. But they haven't made this easy either. The peg the coupler pivots on is part of this main bracing and the cover has a small peg which is a press fit into that pivot. I managed to do the 2 cars this way while trying not to break those cut bars which you can't lever out of the way, no way. Getting the new couplers in was an exercise for the fingers and tongue.
That was last night, tonight I tried the second modus operandi. Decided to lift the entire underbody frame etc off the car 'cause that would mean I could get at the covers and remove/refit more easily. Succeeded in "pinging" one of the cut bars into the stratosphere, but luckily it re-entered and parachuted down a couple of feet away on my bench (amazing I found it it's so tiny). Thinking I had it all free I tried to lift the frame clear, only to find the brake valve (on the end of a couple of flimsy "pipes") had to be levered out of its socket in the body.... Yes, it was certainly easier to change the couplers that way and the G/box cover does press into the pivot quite firmly. But with all the brake "rods" and fittings along the bottom of the frame and it not being a very solid structure, I'm not sure if one of those rods got snapped by me or someone in the factory and I just noticed it when I finished. (most likely me, but I don't want to take all the glory)
Chet ... Looks like that was a very bad collision.
Toot ... I hope your back heels quickly. Sounds like you have some model train projects to keep you busy. ..... The high cube box car coupler change sounds challenging. (Sort of like a Chinese puzzle.)
Here is photo I took last night of an ore train. It includes the AHM cars with others. The AHM cars now have Walthers trucks with Kadee metal wheels and body mounted Kadee couplers.... The AHM cars are larger than the others. which adds variety to my ore train. In the first photo, you can see the steel mills ex-GN Baldwin switcher. Also, the Burlington SD-7 will assist with transferring ore cars to the steel mill.
Good Morning, we have 32 degrees and cloudy. I will be at the desk all day today.
Karl--Nice caboose! ...real glass, cutting something that small must be a challenge.
Nice pictures Garry. Like the NP power. The caption just noted that the wreck was a head on in Washington State. Bad day for the engineer. Hope he bailed.
Good Morning. 38°, overcast with drizzle and a persistent East wind. Not a beach day!
Curt: It's nice to hear you are making further progress on your revised layout.
Chet: Nice photo.
Eric: The finished Tower, resembles a B&O tower somewhat closely. The Fuel Pad also looks good. Nice work!
Karl: Nice job on the brass B&O cabin car.
I received my PRR Baldwin RS12 yesterday. Runs nice and the ESU Loksound captures the Baldwin sound quite like I remember it.
The detail is good for a pre 1966 PRR road switcher. It will blend well with my other Stewart - Bowser Baldwins. I also received a couple of 100 ton coal hoppers.
Dismantled my old wooden work bench yesterday, bought it in kit form from Hechinger in Landover, MD back in the late 1970s.
The Capitals had a nice win over Boston last night. Orioles didn't look so hot vs. Tampa Bay.
Later.
Garry: I really like the depth of your scenery. Good job on the ore cars and train. I couldn't help but notice that your layout also contains a portion of the B&O in Sykesville, MD :cool:. BTW: Nice job on your flour mill complex.
I was thinking I should "dim" out the windows somehow other than turning down the voltage. It's at 5vdc.
Perhaps a little dullcote clear from the inside?
Electrical tape blacking out lower windows as so:
I forgot to finish my sentence about the lights. Those are LEDs as shown below.
I have a 5 meter roll of them. The one with it lit up is running about 8 volts.
I can cut them off in 3 LED sections like I have here.
Supposedly I cut shorten them to 1 or 2 so long as I keep the solder tabs along with them, but that didn't work.
Maybe someone has an idea. I found a video somewhere about it but forgot where that was now.
I wanted to make a 1-LED piece to put in the fuel shack below. A 3-LED piece is too big and too bright. Actually I could wrap the lights around the interior walls since they are sticky-backed. I'd have to put in a trim-pot to ease up the brightness.
I could use a few feet of roadbed if you have plenty.
E.
For some reason my fuel shack pics showed up weird. Try these.
I'm trying to think of a way I could put strip up under the overhang on the flood-loader. Maybe get a piece of tubing to make like a conduit pipe to run/hide the wires. I don't know. Just thinking out loud at the moment.
Any thoughts?
Thanks everybody for commenting about my ore train photos. ...
Joe ... Sykesville station on my layout is for the town of Blackhawk. The station does get around. ... I like the Baldwin locomotive.
Chet .... Head-ons have ended the lives of many railroad employees over the years. I hope the crew jumped in time on that one. ... My NP F7A's are the MRC models which rivet counters criticized excessively. I like them. The NP F3B is a non-powered Stewart model I painted.
Big E ... I like seeing your progress with the locomotive service facility. ... An alternative to black electrical tape to blacken inside windows is black construction paper. I keep a supply of black paper on hand for my windows.
Finally up into the mid 60's again. Sunny and warm. This picture isn't as bad as this mornings. Probably the only injury was to someones pride.
My uncle managed to drop a challenger into the turntable pit in Helena in the early 50's. He blamed the guy operating the turntable.
BigE:
Where did you purchase the strips of LED's? Nice work. The interior lighting of the tower sure makes a difference. I have a old Atlas tower that I would like to add some interior lighting to make an impact.
Thanks.
Greg
BigE:
Greg:
Here you go.
LED strip 5 meter roll here:
http://www.amazon.com/gp/product/B005EHHLD8/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
They are mighty bright at the full 12 volts.
I keep mine down around 8-10 v.
At around 3.5 v or they just turn off.
If I would have had them before I built the tower I would have attached them to the underside of the roof.
Ain't hindsight always just wonderful?!
Eric
Evening All,
Did several chores around the house this morning including laundry. After that I put down the 2 pieces of flex track, soldered it together and powered it. I tested it with my trusty GP7 to make sure polarity was OK which it was so the reverse loop part of the track project is complete. MOH decided that we needed to run errands so we did that. The good thing is we ended up by the hobby store down town so I ran in a picked up the other 2 tunnel portals I needed. After getting home I had to trim 1 side of 1 portal to fit better (thank goodness for plaster), then I painted them and after supper I mounted them. I will post a photo tomorrow.
Tomorrow I'm going to paint in between the tunnel portals black then I have a Xerox box of old student diving records to shred...Joy.
Karl- Very nice work on that caboose.
Garry- Excellent modeling and photos.
BigE- In one of my towers I cut thin styrene and glued them at various levels to simulate window shades. It is easy to do and is a nice effect.
Good evening. 45*F with fog and drizzle in central MD.
Karl, with that I-12, you have just raised the bar another notch beyond my reach! I only used clear styrene in mine...
Eric - The cork is packed and ready to go, just need to drop by the P.O. in the morning. BTW the tower looks great!
Garry, always enjoy looking at your layout photos - getting better all the time! I can't use ore cars with my steel mill, since the area I model [Cleveland] got all its ore by water. Empty coal hoppers were used to transport the ore further inland to places like Youngstown, Pittsburgh and Ashland [KY]. Probably a good thing for me, since I couldn't afford a fleet of ore jennies at the moment...
Has anybody heard from Louis recently? He hasn't posted here since the morning of Easter Sunday.:confused:
Another I haven't seen on in a while either is Rodney from Tassie, see if I can get a PM to him. Hmm, inbox is full.
