Painting a GE44 tonner - How crazy should I go?....
Ian, Thank you!!!
You're very welcome!
Your Q actually reminded me to look at the smaller T/table - The "arms" are spring loaded, and "default" to ~ the width of a 1/24 car shell...... However, they are adjustable, as you can see below :)
One modification I made (on both) - Fix the top to the bottom! - They still rotate, but when you pick 'em up the top no longer falls off! [Don't ask ;)]
EDIT; Sorry 'bout the rotated pic :(
Cheers,
Ian
I have the same stand plus a few others I've made/bought over the years. One o my favorites is one of the mini bar clamps. They're very handy for cars and other items.
Here's what I'm talking about. Not bad for $1.99!
Ian that's looking much better, the lettering looks great!
Woo-hoo, a comment! Thanks! :)
I've learnt quite a bit about Testors decal paper - But no one seemed interested so I pushed on..... They're actually laying down much better than when I took that shot - After they'd dried I poked at the edges with a soft brush + Microsol and they snuggled down nicely. :)
Got a few more to do then I'm thinking a quick spray with semi-gloss clear to seal 'em (?)
Also found a DZ143, so I'm gonna put some kind of light in the roof....
Thanks again for the comment - Appreciated!
Cheers,
Ian
Definitely do the overcoat. Most of the decals I've tried without spraying over have tried to fall off.
Looks like you finally got it to work. :)
So what is the answer then Ian? lol.. I have been following your thread as I'm about to start making my own decals as well for my own railroad scheme..
I certainly admire your perseverance, many many people would have binned the project at the first hurdle, but I for one am glad that you've stuck with it and now you have a decent model to show for your efforts that you should quite rightly be proud of.. No better feeling when someone asks you about a model to say 'I did that!'...
In summary - YMMV, not child proof, usual disclaimers apply etc; I now know that on my printer at least;
- The instructions say to set the job for plain paper - I get *much* better results saying glossy photo paper.
- "My" yellow works great onto white decal paper, but is useless (translucent) on the clear.
- Red & green work a treat on both.
- Don't try and do a large area of solid black - Actually, any color - I found it best to do "stripes" of different colors (potentially containing text) in sequence down the page.
- Inkscape (free) is fabulous for laying out the sheet(s).
- The human eye is *way* too sensitive to straight lines and horizontal/vertical!.... ;)
*Thankyou* for the encouragement! It really does help :) ["Proud" may be a little overstated right now though! But thanks anyway! ;)]
Drifting a little OT (heh, it's my thread after all!), I drilled a hole in the cab roof and am gonna try a little orange bulb up there - I've always used LED's in the past, so this is another new one for me. Anyone interested in the details of the decoder install?......
Cheers,
Ian
Agreed - I just finished "rev 4" of the decal sheets - "Danger, 300V", "No step" etc etc. Hopefully get those applied today and give her a shot of clear. Thanks for the tip :)
Man, this thing is giving me grief!..... Wired the pickups & motor, worked a treat. Put test leads onto F0F & F0R and got everything going on and off correctly (using JMRI).
Moved on to F1 and it won't turn off - It actually reads -13Vish when open circuit, but drops to zero with any load, regardless of switch position. :(
Oh well, try F2 - As we know, that defaults to "on only when pressed" (non latching as it were), but it was turning on my little orange beacon very nicely with a 100OHM resistor. I was poking at the settings in JMRI to get it to latch and my test leads (or a hanging wire) must have shorted as the magic smoke was released (with a surprising amount of "fuss" if I'm honest!) :mad:
I was about to return the DT400R for the upgrade, so will now pop this guy in the package as well..... [IIRC, they charge $10 for a decoder replacement?]
Back to decaling for a while!
Cheers,
Ian
Well, it's almost done. The motor is working, just got to connect the lights and attach the handrails, and we're there.
A while back I mailed Testors and asked if there was a shelf life on the decal paper - The responded with the expected, "yeah, but it's pretty indeterminate depending on conditions etc". I guess 3+ years in a CA garage was too much for it. Anyway, they went beyond the call of duty by offering to send "some replacements" given my address, and a nice new pack of white sheets just arrived. :)
Kudos to Testors.
Cheers,
Ian
Being kind of new to this hobby, I enjoyed your writeup. It has been a number of years since I have done any "kit bashing" or cusomizing of model anything. I enjoyed reading about your trials and sucess.
Thankyou! Too early for success yet..... I'm starting to think this is the "devil engine"!..... :)
Connected the (tested) lights onto the tested "chassis" and was feeling confident when I put it on the track........
Nothing! - Not a damn thing!
Turns out the red lead has become detached at the decoder :mad:
WTF!..... Is it possible to cut the shrink wrap back and get to the pad? [I guess I'm about to find out ;)]
Ian
Yes it is. I actually got it soldered back on, and it all worked.
For a moment!..... Turns out the black, attached alongside the now good red, was hanging on by the proverbial thread, and it too then fell off :(
The resultant fix-it attempts then interfered with the red pad, and it all went down hill from there - It hasn't let the smoke out, but I dunno how to un-short the two pads (?)
Ian,it looks a lot better with the R.R. name across the hoods!
Thanks! - I was kinda satisfied with the results of a little weathering. Was looking forward to playing with the beacon as well. *Another* decoder for the return pile!..... [I swear I didn't abuse it - It honestly looks like the red & black were never "properly" connected :(]
Oh well - Almost!
Cheers,
Ian
Hey the loco's looking great!
Sorry to hear of your 'lectrical woes tho, I have a pile of "smokeless decoders" and some that the wires let go also. Maybe I'll try what you did...
Thanks!
I only just noticed that one of the windows in the pic had "blown out" - Rather than the thick clear things I'm trying Micromarks "Micro Glaze" - It was looking OK until I sprayed the clearcoat [another lesson learnt!]. I may still cut it out (easy) and redo it or just use the plastic - Dunno yet.
FWIW - I'd say that with a pencil tip you've got one-shot at getting a single wire back in place. After that, all bets are off..... ;)
Cheers,
Ian
So much for every decoder being tested after assembly!
I installed my first decoder last week(all went perfectly!)
and read the Digitrax decoder manual.
Good job & nice to see credit where it's due for the manufacturers that go the extra mile!
Any other all round shots of your finished handiwork?? (With a tad more lighting!) lol...
