If you already have a Zephyr - don't waste it, go with the Super Chief. If you have any thoughts of going to a signalling and detection system later on - Loconet has a huge advantage over ANY other system. All the others use polled serial busses. Loconet is a peer to peer network. This is why there is little need to ever upgrade the Digitrax command stations. OK, out of the box the Zephyr only has 10 functions. Plug in a DT400 and you have 12! There are MANY third-party manufacturers who make signal and detection equipment that plugs into Loconet - you don't have to stick with just Digitrax stuff.
And as I said elsewhere, this whole "easy to use" argument has long worn out it's welcome. Please, PLEASE tell me what is so 'fiddly and geeky' about selecting and running a loco with Digitrax? It's EXACTLY the same as every other system. Press the loco or select button, type in the address using the numbers, hit enter. Turn knob one way to go faster, the other way to go slower. Press the direction button to go the other way. As for programming - this is why we have wonderful free software like JMRI DecoderPro. No one ever need to keep stacks of manuals on hand to look up the fact that CV89 on a Brand X decoder makes the loco hop, skip and jump when you press F5. That part works with any system with a computer interface - except MRC since they FOOLISHLY have decided to make their computer interface and software proprietary and not work with the JMRI people like Digitrax, NCE, CVP, and Lenz.
ANd on the topic of computer interfacing - another Loconet plus. All traffic sent to the rails is echoed on the Loconet - so you can create a control panel in JMRI, and have a lever and indicator 'lights' for switch address 10. You can click on the screen and operate the turnout. or you can use your throttle. If you use the throttle, the screen will change because the interface will 'see' the command on Loconet and allow JMRI to respond. No other system does this! This is how I get away with using very inexpensive NCE Switch-It decoders to run Tortoise switch machines.
I use very few Digitrax decoders. Most of the ones I have (well, had) are NCE and TCS - for a low cost decoder you can't beat the NCE D13SRJ, they're like $12 each in a 10 pack. And like any other brands of decoders I've used, they work just fine with a Digitrax system, as was intended.
As for functions - do we really NEED 28? Are we playing with toy trains or accurate models? How many things do we really need? Most of those above 12 are used on a few sound decoders so you can have more than the usual train sounds - adding things like 'radio chatter' and conductor platform calls. Or in the case of MTH, train wrecks! Wow, think I'll switch DCC system right now so I can make train wreck sounds.. Oh yeah, with JMRI you can have an on-screen throttle that, even with Digitrax, provides all 28 functions.
--Randy
--Randy
