Building my layout, planning to go DCC in the near future and have a few sound engines. Plan to buy the Digitrax Empire Builder DCC set up. For now, I have 3 locomotives, all DCC ready (plug in) but they do not have chips installed. I'm gonna buy a cheap $40 throttle to run for a few months to run test trains since the track is 90% (just lacking small yard and 2 industry spurs). Would one feeder be enough for now to run DC consistently? Layout is roughly 10x10'. All joints are soldered except a few random joints in tangent track for expansion. If I ran 3-4 feeder wires around the layout, would it still work fine with DCC?
Here's my layout in a 10 x 14 room:
It is wired for DC/DCC. No blocks or districts.
I used 12 ga. romex for the main power supply bus wires. I only used the black and white wires after stripping off the outer insulation sheathing. (I saved the bare copper ground wire for use somewhere else I may need it)
These 12ga wires connect to the DC output on my MRC Control Master 20 power pack. I then run 22 ga. feeder wire from the rails to the main bus wires. I used a wire stipper to expose a bare section of main bus wire then wrapped the 22 ga feeder around the exposed section and soldered it. You could use commercial connectors if you wanted but that's more expensive.
My turnouts are already DCC friendly (which means the frogs are gapped and powered via Caboose Industries power routing ground throws). I have more feeders than depicted because of the turnouts and the need for gapped rails.
I never had any problems getting power to the rails with this set-up. I could run two or three locos simultaneously BUT since there was only one controller they all moved at the same speed and stopped/started at the same time.
The green wire you see went from the hand held controller to the power pack itself. MRC's unit used 4 conductor phone wire and RJ11 connectors so you could daisy chain phone jacks all around the fascia board and use the plug to move with the train ( the MRC unit has memory when unplugged).
I have since converted to The Digitrax Super Chief DCC unit. All I did was swap out the MRC unit for the Digitrax one. Very easy and painless.
The biggest concern you should have is that your DC power pack/throttle/controller has enough amps to run a large layout. As long as it has that then you should have no worries.
-G-
