Epimetheus
Has anyone used wire-in-tube for ground throws? I am looking for small diameter plastic tubing and stiff wire. It might be used for RC planes, I don't know what it is called.
Previously, I used Caboose Hobbies ground throws at each turnout and coat hanger wire for sliding Kadee under track magnets. I would like to use manual control but put it at the edge of the layout.
If you are interested, I build a simple sliding mechanism for each Kadee magnet. I bent thin aluminum sheet (soda cans) into C-channels. On the bottom of each magnet I epoxied a grommet from a Pop rivet to grab the push wire. Pull, and it stopped exactly under the track. Push and it moved out from under the track.
