Walthers 130' DCC Turntable Issue
fcwilt
Hi,
I am in the process of install a current Walthers 130' DCC turntable.
For the most part everything is going OK with one exception.
If I am reading the documents correctly the turntable comes programmed from the factory with two positions and these two positions are 180 degrees apart.
Is that correct?
The problem I am having is these two positions are NOT 180 degrees apart. They are off enough to cause a problem.
Anyway to adjust this?
I have reset the turntable and calibrated the turntable many times.
