Engauge18
Hello All,
New to the forum.
Have built up the 'famed' Gulf Summit & Susquehanna Lines' railroad from the Atlas Nine N Scale Railroads book (N-109). For those not familiar, this is an old book, first published in the 70s. It's all analog wiring and code 80 track. It's a cookie cutter bench work design that has two separate railroads each with double track. It can run 4 locos simultaneously and independently, all in 4'x6'.
I built my version of this on a tilt table frame.
Question for the group: having trouble writing the second cab on the main line. The upper level has no issues with running 2 locos, it's the lower level that gives the issue.
The wiring diagram calls for sending a lead from one DC terminal on each cab to the main line 'C1'. When i do this though, only the second cab can run a loco.
I tested each cab and loco separately and they with fine. It's something in how I'm connecting the two cabs.
Thank you for your help!
New to the forum.
