Steamfreak
CEO of the LCP
just purchased a few days ago a B'mann DCC equipped engine....It doesn't work so well on DCC, but it works great on DC....Go figure...
http://www.modelrailroadforums.com/f...ad.php?t=17093
__________________
Gus (LC&P).
Steamfreak
#8 Yesterday, 01:05 PM
Selector
Engineer Join Date: Jan 2006
Gus (LC&P).
Gus, if it works at all, it must be a problem with settings. The general rule with DC/DCC engines is that if they run okay on DC, they should be just as well or better on DCC, but with more do-dads. If they don't run well in DC, they'll probably be entirely crappy in DCC.
So, if you have a decoder in a B'mann engine, and you are vexed, it suggests to me that the various CV's that control movement need some spanking. Figuring out which, and how many swacks, is the puzzle. It generally means getting into the manual for the decoder and pondering your next best guess. Try dither, torque compensation, V-Start, and so on.
Crandell
Selector
#9 Yesterday, 05:41 PM
Steamfreak
Crandell, I plan to spend a few hours (I hope) tonight messing around with it. Hopefully I'll get it working properly....
__________________
Gus (LC&P).
#10 Yesterday, 06:52 PM
diburning
The New England Railfan Join Date: Sep 2008
It's a bachmann engine meaning that the circuit board has capacitors. The capacitors need to be removed for proper DCC operation.
#12 Yesterday, 07:04 AM
diburning
The capacitors are there because of some European electromagnetic interference standards. They will cause DCC operation to be erratic and unreliable.
Bachmann knows that the capacitors cause problems. Removing the capapcitor is part of the instructions that come with the loco.
#13 Steamfreak
I popped the tender open last night with the very malicious intent of cutting the capacitors off....Look Ma...No capacitors..!! At least none that I could recognize (little yellow saucers...). All the components are surface mounted, and they consist of rectangular chips with several soldering pads.....Nothing that looks like a capacitor, induction coil...anywhere. Sooooo....
I should'a taken a picture...but the "joy" was so overwhelming, I just buttoned it back up...
__________________
Gus (LC&P).
#14 Yesterday, 03:54 PM
Update....Here's a pic of the offending board...Could those widgets labeled C1, C2, etc...in the upper left hand quadrant be the capacitors..??
Note: I disconnected the decoder in order to take a picture of the board only...
__________________
Gus (LC&P).
Steamfreak
Selector
Gus (LC&P).
Crandell
Selector
Steamfreak
__________________
Gus (LC&P).
diburning
diburning
#13 Steamfreak
__________________
Gus (LC&P).
