GMTrainNut
Hi all, glad to have found this forum!
I used to do a lot of custom painting, then took a break from it for many years. Started up again about a year ago, and used the opportunity to make the transition from solvent based paints to water based. I'm primarily using Pollyscale now, and have gotten comfortable with it.
I am having some issues with surface preparation that I'd like to bounce off you guys. The first time I did some test painting with Pollyscale I followed my old procedure: Wash the shell in warm soapy water, rinse well, let air dry, and paint. Not sure if it's the water based paints or the fact that I moved and we have harder water here, but stains and splotches showed through the paint after it dried. Fortunately it was only a test shell so it wasn't a big deal.
Having read that distilled water might work better in cases like this I tried another shell, this time using distilled water and soap for washing. Only problem was rinsing, having to buy it in gallon jugs I couldn't exactly do a super thorough rinse. I tried to compensate for that by a short soak in denatured (or maybe it was 91 percent isopropyl), but I still wound up with some stains.
Now I got to the point where I was asked to paint something for a friend, and I resorted to a lengthy soak and scrubbing in alcohol, and it seems to have worked okay.
I'm guessing that I need some kind of water softener system, but in the meantime I'm still in need of consistent results sans tap water.
So I'm wondering if any of you have had similar issues, what methods you use to prep shells for painting. I try and avoid expensive alternatives like Floquil's Plastic Prep, but if that's the route I have to go I will do so.
Thanks for any tips!
