funnelfan
While Daylight GS series 4-8-4's were the queens of the passenger trains and the Cab Forwards were the Kings of the Mountains, to highball the long freights across the valleys between the mountains and out through the desert, there was one preferred type of locomotive for SP enginemen. That was the 5000 series "Southern Pacific" type, 4-10-2's. Representing the ultimate in rigid wheelbase steam power, the 5000's had three cylinders and a booster engineer on the trailing truck. The 4-10-2's could haul tonnage at speed and power through the lesser helper districts on the mainline without an assist. You can see why SP freight engineers were almost giddy to be at the controls of a 5000! Nicknamed "Stuttering Decks" because of the odd exhaust from the third cylinder (2-10-2's were known as "Decks" on the SP). Mechanics in the shops hated that inside driving rod powered by the third cylinder, as the bearing had a tenancy to fail. SP bought the first 4-10-2's in 1925 to power trains through the mountains, but the rigid wheelbase quickly proved hard on the curves, and the 49 5000's were reassigned to straighter runs, notably the desert sections of the Sunset Route.
