Sarnia modeller
Hello:
I'm modelling two overpasses in HO. They would best be represented by the Rix Products 0111/0112 modern overpass due to the exposed concrete I-beams at the side, with the addition of the 0124 wrought iron railings. I assume the railings can be used on any Rix overpasses - if not, I don't see how they would be hard to install.
I already have two "early" 0102 overpasses with piers. The sides and railings are incorrect for what I want to model. However I notice Rix has 0105 "overpass beams". Are these the same as the I-beams in the centre of the overpass? If so, I can just correct my early overpasses by using these beams on the outside, omitting the odd cornice-type protuberances on the sides, and adding the wrought iron railings.
What about the deck? The early deck has large concrete squares. This is not what I usually see on prototypical modern overpasses, but I haven't closely seen the model.
Attached are photos of both overpasses. The Rix overpasses are really very close models, but I definitely need the exposed concrete I-beams on the side and the wrought iron railings.
I just want to know if I can re-use the early overpasses with some changing of parts for only a few dollars.
Thanks.
Thanks.
