Okay, here's another revision, N scale layout. The very bottom track is the spur line that goes up a grade to the yard on the bottom right for my ore mine. The switch on the curve on the left is for the main.
Up at the top, the very top track is a yard lead that can also be used as the main if necessary.
I'm thinking of doing a single-track to staging that spurs off the section in the tunnel on the right, going straight up to some removable staging.
I think I've made it more operations friendly as I've looked to see what is absolutely necessary and what doesn't make sense.
If anyone has any suggestions or revisions, I'd be happy to send the xtrkcad file.
FYI, I'm using code 80 Atlas, those visible switch machines likely will be replaced by motors or something, I haven't decided just exactly what, yet.
And also FYI, I'm getting the digitrax zephyr to run it.
