Hello,
I am re-painting a bunch of my HO shipping containers. They are white and I am painting them brown, red and orange. Will the classic can of Krylon work or will that apply too thick? Would airbrushing be a better choice? Thanks for any advice!!
Will
Certified Great Northern Nut
I have pretty good results spray-bombing. Just apply light coats.
If you have an airbrush, that's always the best choice. If you want to use spray cans, apply the paint in very light mist coats. Don't try to get complete coverage all at once. That usually leads to a repaint.
I've used this method, and I also heated the spray can up in some warm water, seems like the mist had a better pattern to it.
good tips, thanks!
Yes, this is especially important if you live in a cooler climate, or during the winter if your hobby room is cold. Spraying from a cold can may lead to the "orange peel" effect when it dries; this applies to clear coats as well (e.g. gloss coat, semi-gloss, etc). I usually just run the sink until it gets hot, then fill a plastic cup about half full and set the spray can upright in it for a few minutes. No need to use super-hot or boiling water.
