the axle gears cracked? i think that you can pull the cover off of the bottom of the trucks and inspect the gears. i know the gp30's had this problem. heard it was also an issue with other proto blue box units. it is the gear that holds the two wheels together. you can get the replacements, you can also get the athearn sd-40 axle gears. they are alot cheaper and easier to get, if that is what is wrong. they just push together.
